The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Questions View all
Won't turn off running on on battery (Não desliga só com bateria)
Won't turn off running on on battery.
I press the power 1..2s and nothing
If I plug in the power then pressing 1s the power button turns the console off.
When is running with the power cable inserted (and connected to an outlet) disconnecting the power cable turns the console off.
The battery only charges half way.
Different battery... Same problem.
Different Power board... Same problem.
Não desliga só com a bateria.
Carrego 1..2s no botão de power e nada.
Se ligar o carregador, carrego 1s no botão de power e desliga
(o carregador tem que estar ligado à corrente)
Se estiver com o carregador ligado e se desligar o carregador da corrente ou se retirar o cabo da consola, ela desliga-se.
A Bateria parece não carregar totalmente... (retestando)
Add a comment
There is only one answer to this problem and it involves buying a new battery and a new charger. sorry
2 Comments:
I have 3 chargers and 3 batteries.
The problem does not seem to reside with them.
The batterie charges to a full in other nintendo with the same charger.
But thanks.
by
i am sorry that i could not help
by
Add a comment
Same problem here. Could you find an answer please?
Add a comment
Add your answer
Luis Ramalho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 74
