Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5197 Questions View all
mother board repair, water damage
Water damage limited to top of the phone; no signs of any water under the top 5 sockets. there was a bunch of corrosion up there but I cleaned it with non-sweeping ultrasonic cleaner. I'm newbie for soldering but assembling the needed tools for this. the extent of my soldering knowledge is from the recent ifixit videos with Jenna. I could use some expert eyes on this to determine what I need to do; parts I will need. Or practical advice that should send in for repair and learn on some other boards. Phone seems fully functional except for the lcd, digitizer, and likely the two camera sockets. I was able to restore fully to iOS 9.0.2. getting into recovery mode (with use of the home button) and iTunes.
Score 1
Add a comment
Most Helpful Answer
The camera socket seems to have 1 pin completely burned out, clean again. And I still see some residual damage on other connectors.
Also I recommend flipping the board over, peel off the top shielding sticker to see the water damage below. Touch panel, home button and LCD backlight have relatively high voltage inside the phone, for this reason the chips and connectors are very likely to have water damage around them.
Score 1
Add a comment
Pictures of the Back
Add a comment
Add your answer
Breadman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 370
