The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1529 Questions View all
My iPhone 5c wont "slide to unlock" or answer calls.
Hi, i've had my iphone 5c for almost 2 years, and its just now deciding not to unlock for me. I realllyy don't want to go to the apple store to save me some money, is there anything i can do to help is? Ive tried a hard reset and it didnt work at all.
Score 1
Add a comment
Chosen Solution
Hopefully you've recently, or now can, so a backup. Try dfu and doing a restore to one of these backups
Score 1
Add a comment
B Burton,
Try to restore your phone. after restore if you observed same fault you will have to fix it on hardware level
Here you can find front panel replacement guide. follow it and make sure that touchpad connector properly connected to the logic board. if not reconnect the contacts
if above two steps not works for you, you will have to replace front panel (display with touchpad)
iPhone 5c Display Assembly Image
Guide
iPhone 5c Display Assembly Replacement
Difficulty:
Moderate
5 - 20 minutes
iPhone Image
Guide
iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.
Difficulty:
Very easy
10 - 15 minutes
Score 1
Comments:
Great. You just said what I said
by
Add a comment
Add your answer
B Burton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 236
