The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3825 Questions View all
Screen went dim and won't come back
I connected and external display and it works fine, I replaced the internal display with a new one and it is doing the same thing. Logic board?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If it works with an external display the logic board is probably good. The most likely cause would be the inverter board or the cable from the logic board to the LCD.
MacBook Core Duo Inverter Replacement
Score 2
Comments:
+ agreed
by
Add a comment
This is just a guess but the back light of the display could be a separate circuit then just the LCD it self. I ran into that once on an IBM.
Good Luck!
Add a comment
Add your answer
deanpeters will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 917
