iPhone immediately turns off when plugging in USB cable
Hello everybody,
I'm a big user of Apple products; had intermittent network problems with my 5S , 3 days ago. I decided to replace the dock, which contains the antenna.
After this, suddenly, the iPhone encountered a problem which occurs since 3 days;
As soon as I plug in any USB cable, the image becomes full of lines and lose colors, then, the screen is black (the device is not really powered off, but the screen stays black).
When I remove the usb cable, the device reboots. It is also the same problem in the other way (I remove the battery, plug in the cable, put the battery back) : it boots and as soon as I remove the USB cable, the same problem occurs.
In that last case, I noticed that, if I let the Lightning side plugged in, and if I remove the USB side from its source (computer, wall charger, ..) it will never do any problem. The problem occurs with the LIGHTNING, not with the usb source.
Already tried to replace battery, screen, dock, camera, .. it always do the same.
I also noticed that some batteries which works with another 5S, won't work with this one.
Any help for me ?
Thank you !
