Why do I get getting an fh error
I've changed all parts reg. FH and its still doing this. Is there a re set button?
wineknow1983, it would help if you can tell us what you mean by all parts reg. As you probably already know the error code can come up with water supply valves that are not turned on, the inlet screens are clogged and the pump strainer/filter is clogged. It can also be caused by a bad drain pump motor. I suggest that you download the service instructions from the bottom of this page and run the diagnostic cycle. Then let us know what you found. No, there is no reset button. Unplugging the machine and leaving it unplugged for 15 minutes will reset it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 145
