A DECT 6.0 interface digital audio baby monitor manufactured in 2014 by VTech.
3 Questions View all
Why is my device beeping?
Even when my parent units and baby unit are in range, and there are no large metallic objects in the way, my device will beep. How do I resolve this issue?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Check to see how many beeps the unit produces. If the unit has three loud beeps, this means the baby unit is out of range. You must be at least 3 feet in range, any closer and your device will have static. You might also have low batteries, try replacing the batteries by using the battery replacement guide. If this does not resolve your issue, consider the following guides on speaker and motherboard replacement, as that would be the next step in resolving the unwanted beeping problem.
Add a comment
Add your answer
Melany Colon will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 58
Past 30 Days: 269
All Time: 5,589
