Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
887 Questions View all
Why does my MacBook require battery removal to restart?
I have a MacBook which shuts down and then requires the battery to be removed and replaced before it will restart.
When it is in the locked state, the charger indicator light does not illuminate. The battery level indicator also does not illuminate.
Once the battery has been reconnected, it works as normal for a few weeks.
The last time it locked up, it was connected to the charger and was charging overnight.
Coconut battery shows that the battery is at 80% of design capacity.
The OS indicates that the battery condition is 'Normal'
It has a cycle count of 643
Since the last 'lock-up' I have reset the SMC and PRAM, also repaired disk permissions.
The OS is 10.10.5
Is there anything else that I can check/do to resolve the problem?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Check the battery checker button to see if it is sticking?
Your battery is pushing its lifespan, it may be time for a new battery.
Score 2
Comments:
Thanks Mayer! Was on the bus home so my typing was a bit off ;-}
by
Add a comment
Add your answer
esadien will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
