Released in 2011, the Sony Cyber-shot DSC-TX10 is a compact, point-and-shoot digital camera. Available in black, blue, silver, green, and pink.
4 Questions View all
Preparation for using the Cyber-shot DSC-TX10 in the water?
I'm hesitant to take my camera in the water even though it's advertised as waterproof. Is there anything I should know before using my camera in the water?
Add a comment
1 Answer
Chosen Solution
Even though it's advertised as waterproof, you should follow the instruction manual for your camera to protect your device.
  • Don't let any sand or dirt get into the battery/memory card cover or multi-connector cover.
  • Never open any parts of the device (battery/memory card cover, multi-connector cover) in the water or when your hands are dirty.
  • Set the camera on the "underwater" setting using the touch panel before you use the camera in the water. Hide the icons on the touch screen while you're using the camera near water (the icon to do this is on the right side of the touch screen).
  • Make sure the device is completely closed before using it near water. The yellow marks under the slide lock should not be visible.
  • After using your camera in the water, always clean it to maintain water-proof performance. Don't open up the camera until you finish cleaning. Clean the camera by letting it sit in pure water (in a clean bowl) for about 5 minutes. Press the buttons and slide the levers and open the lens cover inside the water to make sure nothing is lodged around the buttons or lens cover. After 5 minutes, shake the camera gently.
Add a comment
Add your answer
Marissa Santana will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 325
