Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
781 Questions View all
Question Closed
Doesn't charge and doesn't turn on
Hi guys I have this Mac that I have tried about everything.
Tested some of the components on the logic board. I can see some voltages, to be honest I dont really know wht component gives what voltage.
Would you have any tip about dead logic boards?
Any known component to be replaced, any ideas?
MagSafe doesn't even show any light. I tried different MagSafe as well as another battery.
2 Comments
Lets backup here a bit. What happened to the system. Did you bang it or get it wet? If you press the built-in battery checker does any of the LED's light up? Looking at the AC adapter what is the wattage of the unit sadly its in light grey ink so hard to see or even read. Are the two AC adapters the same?
by
i got it wet.basicly... but mother board wast too wet..i cleaned with alcohol..no luck.. 60w and 85 w .. adaptors... they both 16.5-18.5...v tested with other macs .. all fine..no lights comes on at all...
by
Add a comment
1 Answer
Chosen Solution
Sounds like this system needs quite a bit of work here.
As the battery tester doesn't work we know the battery will need to be replaced. We also know the MagSafe power logic is damaged as the AC adapter LED is not lighting we also know the main logic board is also in need of repair as well. You may also have to replace the keyboard and/or the trackpad.
At this point I'm not sure this worth all of the labor and parts to fix.
Sorry for the bad news ;-{
Score 1
1 Comment:
well i have tested logic board on different mac.. same thing ...:(
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 110
