Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
31 Questions View all
How do I fix the spring for the SD card?
I have to fish the SD card out of the SD slot. I am afraid that one day it will get stuck.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Gently remove your SD card with a pair of tweezers to avoid further damage. When you insert the memory card, does it click into place? If not, there might be something small blocking the SD card contact. Carefully turn your camera upside down to remove any loose debris. Make sure you are using the correct memory card size for your camera.
Add a comment
Make sure to check inside of the SD card well there might be something soft blocking the contact point.
Add a comment
Add your answer
Javier pulido will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 76
All Time: 1,026
