The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
648 Questions View all
charging paused, temperature battery too low
my samsung galaxy s4 gt i9500 won't charging, i check batt temperature is -25C , i already replace usb cable flex but still not work ,
sorry for my bad english
Score 1
Comments:
take out the battery and keep the phone under direct sun light for few minutes and try charging again
by
Add a comment
Chosen Solution
hendri, since you " check batt temperature is -25C" then it is definitely to cold. Double check the -25C.;-) The usual causes for this error are issues with the battery connector, failed btemp line on the circuit board, bad battery, bad charging port flex. So if I would fix it I'd start with a new charger, then a new battery, then do some fault finding on your logic board.
Score 2
Add a comment
Most Helpful Answer
hendri ,
just clean the battery terminals
Score 3
Add a comment
Add your answer
hendri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,247
