Repair information for the Pony 42, a Troy-Bilt brand riding lawnmower.
23 Questions View all
Question Closed
mower starts. sometimes but won't. keep running changed carb and filt.
See above bus on troy bilt self propell
Add a comment
1 Answer
Mine has this issue, and all I do is push forward on the metal slider under the carb / safety stop at the end of the metal cable that goes from the safety stop handle to the engine, once I pull back the handle and before I pull the starter cord. I am pretty sure if I replaced the cable (I wrapped it around the handle one too many times and I think it stretched it out) that it would correct the problem, but that does the trick every time. Hopefully it also works for you! If it doesn't, good luck to you and this is at least free to try.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 112
