What is the part # for the IC chip on the a1370?
I have identified the IC chip on my motherboard and I would like to replace it. When I try to purchase it I found that the LP8550 chip has several versions. Which one is the right for this model? Does anyone know? or are all LP8550 the same?
Comments:
Geekygirl, what is the 820-XXXX on yuor logic board? Post some images of where the IC is located on your board. Use this guide Adding images to an existing question for that
by
thanks oldturkey03 ;) the mobo # is 820-2855-A
by
Why do you want to replace it? Every time the manufacturer makes a new batch of chips even though its the same they change some of the numbers at the end.
by
Thanks John. I mac has no power, and I want to try replacing this chip.
by
I try to buy it from digikey, but there is more than one. http://www.digikey.com/product-search/en...
by
Show 1 more comment
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Geekygirl, check the datasheet right here. Looks like straight LP8550 should work
Score 1
Add a comment
Add your answer
Geekygirl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 107
