The HTC EVO 3D is an Android smartphone developed by HTC released exclusively in the United States through Sprint.
12 Questions View all
Why is my battery life bad? Why does my battery not charge?
My battery doesn't last as long as it used to. My battery only lasts a fraction of what it is supposed to and at times it doesn't even charge. Can someone please help me figure out what may exactly be causing this issue?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Your battery is probably damage. In this case, you should go and buy a new one. Also, you will need to check if it correctly installed. In other cases, the fault may be of the charger. If the charger is not working correctly or if it’s broken it won’t charge correctly the battery. Refer to the Troubleshooting Page at www.ifixit.com/Wiki/HTC_Evo_3D_Troubleshooting for more details in order to fix this issue.
Add a comment
Most Helpful Answer
Matthew Pope, sounds like you will require a new battery. This teardown will show you how to get to the battery.
Score 1
Add a comment
Add your answer
Matthew Pope will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
