Red X after HDD, screen and jack replacement
Good evening all,
I'm having some trouble with my 80GB iPod Classic.
Here's the story: I started by replacing the screen as the original was covered in scratches and dead pixels.
All was well, almost.
(I think) I was a little careless during the reassembly and must have inadvertently damaged the earphone jack assembly. It worked totally fine, however a few days later I lost audio in one of my earphones (note this iPod has had two jack/hold replacements in it's long life, though they were performed by a third party company) this whole ordeal was the first time I've tinkered with it myself.
So seeing as I'd replaced the screen myself I thought I'd have a go replacing the jack/hold. Which I thought was fine.
During the process I disconnected the hard drive as I was automatically in screen-replacement-mode and totally forgot that I was following different instructions. When I finished this reassembly I was faced with the dreaded circled red X. As I've had an issue with my hard drive in the past (previous red X during use, banging it off a table fixed it) I assumed it's time had come and I have purchased a new one. This replacement also resulted in a red X.
Performing a diagnostic shows everything is fine except for the HDD, which cannot be opened. "[Can't Open Device] ERROR! Diag Halt"
The ribbons seem to be connected fine, though I have noted that the problem has only been around since I disconnected the HDD from the logic board during the jack replacement. Could this be as simple a fix as me just not doing something quite right with the ribbons? I can't for the life of me figure out what else it could be.
Any help would be hugely appreciated.
Thanks,
James
1 Comment
Thank you both for your speedy replies.
Argh, this is so frustrating!
I like the idea of the Zif connector, I'm just conscious of how much money I'm spending on bringing this thing back from the dead, I've probably spent about £60 so far with little joy.
I can still hear both HDDs "whirring" when I fiddle with the diagnostic, to me this suggests that the iPod definitely acknowledges them but can't do anything with them. I can't see how it could be a connection issue though, yet all the signs so far point to that being the case
by jamescdavies
