The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3829 Questions View all
Do Macs have bios or some diagnostic built-in software?
Frst time mac repair, 24 year pc tech. My daugther had a problem first with keyboard and second with mouse pad both fried up. So I installed super mouse and the tiny keyboard bluetooth both. I dismount keyboard top to verify if it was not well connected after reading some possible solutions but it was well connected to the board. Restore did not recognized both what else can I try to fix or diagnose top keyboard and mousepad.
Lamboy, Puerto Rico
Its a Mac-Book I override problem using usb mouse and keyboard but original problem is present.
Update
I think it is a A-1181 core 2 duo with a rare name santarosa or other rare name because it has 3 cables in the airport card as I remember and a different form in the right black cover were in my case the backup battery is visible.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
No - nothing with user access. Sounds like liquid was spilled on the keyboard - either use the work around or replace the top case. Separate parts are not available - they come as one complete assembly.
Score 1
Add a comment
Hey there, if you are good at dis-assembly, you may check the trackpad/keyboard ribbon cable. I had the same problem with a macbook pro.
Problem is, I haven't found somewhere that sells *just* that cable, so you may be looking at a few hundred dollars in parts for the whole top assembly.
Hope this helps!
Mic-B
Add a comment
Add your answer
eduardo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,254
