2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
Question Closed
Can't open back case to remove dust from fans
Got all the screws off, but can't seem to pull the bottom casing. I can partially lift the casing near the fan side, but something seems to be holding the case down from the battery side.
Add a comment
Chosen Solution
There are magnets still holding the bottom panel to the chassy. Make sure all 10 screws are out and lift harder.
Score 2
1 Comment:
Pop it right off. Had to be a bit more forceful I guess.
by
Add a comment
Make sure you lift from the vent side as there are 2 clips that hold it in place also make sure you remove all 10 screws
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
