The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
1713 Questions View all
Wont charge, keeps flashing and disappering?
My Samsung Galaxy 4 tablet wont charge. I plugged it in and the battery sign appears but it wont start charging. It either freezes on the battery sign or the sign appears and disappears. The tablet is off. Wont turn on. When I try to turn it on, it turns off quickly and the battery sign appears.
Score 5
Comments:
now the chagrining animation wont show up
by
Jojo, what model of the Galaxy 4 is your tablet?
by
Um model? all I know is that its a Samsung galaxy 4 tablet. I tried a phone charger again and it is starting to charge but the screen keeps flashing black and when I turn it on it automatically turns off. should I just let it charge for a while and then reset it when it turns on?
by
why does a phone charger work but now the one that's made for it?
by
What size is the screen? The Tab 4 comes in a 7" and a 10.1" version?
by
Show 16 more comments
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
Have you tried a different cable or try moving the connection around carefully to see if the charging port is broken you can also try a reset. Power button and volume down button at the same time till it says its resetting
Score 8
Comments:
I tried multiple charging cables. I even bought a new one. I also tried the reset option and it won't work :( is my tablet officially garbage?
by
How old is the tablet it does sound like its time for a new battery
by
My new cell have 4 virus, what I do
by
I'm having this problem only with two replacement batteries I ordered. Is this a known issue? Can it be fixed or is it time for a return?
by
I have a galaxy tab I'm repairing for a client. I had the same issue as above with the power flickering and then shutting off. I tried a new micro cable and it fixed the issue. Thanks for the suggestion as I didn't realize this cable was damaged.
by
Show 2 more comments
Add a comment
Most Helpful Answer
Firstly, the battery is not holding a sufficient charge to boot because the LCD screen is constantly turning on. This causes a tremendous drain on the battery for a split second, if your battery is completely dis-charged like mine then you will never get ample charge into the battery for it to turn on hence why the screen keeps failing.
1. Open the back cover.
2. You will see 3x vertical ribbon cables. Carefully remove the on on the right, it is marked LCD (Convenient)
3. Plug your charger in and leave it to charge for at least 8 hours. (Use the wall socket adapter, it produced more current than a USB port on your computer) Now that the battery is not being drained constantly by the display the battery will have a chance to get some juice into it.
4. After you have left it to charge for some time unplug your charger (Crucial) , re-insert the ribbon cable for the LCD you removed making sure that it is in all the way so that the lines on the ribbon and the board are aligned.
5. Power on.
If it boots great. If not it may be time to purchase and replace the battery ($25 on eBay) otherwise may be time to retire it. (3 years old may not sound like a lot but in the IT world it is 2 lifetimes)
Good luck!
Score 9
Comments:
Same problem is with my Samsung but my phone has some battery left. It was not charging , so I tried to charge it through switching it off and then it's kept flashing and disappearing. So, I switched it on and then i connected charger slowly, it's started charging.
And That's meaning charging port of mobile is broken.
by
This worked for me! I accidentally unplugged the touch screen ribbon though instead of the LCD. Looks like my battery was/is shot and was near zero %. I imagine it only has a few charges left on it before it's completely toast. Will eventually replace the battery.
Thanks Gavin!
by
I can't do that with my samsung tab because you can't open up mines help what can I do
by
This worked for me. I had replaced charging port but still wouldn't charge. This did the trick. Keep it charged from now on. Thanks Gavin.
by
I have a samung tab 18.4 and when the wall charger is plugged in, it continues to beep on and off, and the charging display also goes on and off. I bought a new charger, and problem still exists. I called Samsung help desk and they told me to take it to best buy and let them look at it. You pay all this money and nobody there knows or cares that your frustrated.
by
Add a comment
Anyone tried the volume down + power button hold down trick for 5-10 seconds?
Score 6
Comments:
Yes, I did try that and the on screen came on. However, it still won't charge or power up. My screen continues to flash on and off.
by
Thank you! It's so good that people bother to give solutions. Thanks!
by
My new galaxy 8 is default
by
I found out on my Samsung galaxy tab 2 10.1. That the hard drive is bad so I have to get a new mother board since the hd is integrated onto the MB. Ugh
by
if you're charging your tablet with your computer it will cause that to happen too, switch to a normal charging source
by
Add a comment
I had the same issue. This might sound weird but this is how I solved it. I tried all the different button combinations didn't work. While trying the combinations I realised the tablet felt cold. Kept the tablet against my body while charging for about half a hour while watching a movie on laptop. Body heat seemed to have warmed it enough to start charging. Suppose you could try other warming methods.
Score 3
Comments:
Well this would explain alot. I put my tablet on my window cill and the air is freezing outside. Im quite stupid. Hopefully this works!! Thanks
by
this worked for me.... only took 10 minutes. You are a lifesaver
by
I can't believe this worked. Lol thanks!
by
Hair dryer... 5 minutes!
by
Add a comment
Right now it sounds like you are having battery issues. what is the voltage/amperage of the phone charger you are using? If you do not have that written on the charger, what model is the charger?
Score 2
Comments:
You just said it right on the dot. It's a battery shortage. Both of my Samasungs did it and I refuse to get another one. They are both from Sprint bc I was eligible to get "Free tablets" and both did it within less than 3 months. It's aggravating and for whatever reason it's all android or Samsung products that always had issues with batteries bc my LGs and Samsung phones had the same issues with the batteries. I honestly think and believe when they say you're getting a new phone and tablet they give you refurbished ones bc my "brand new iPhone 6s I got from the actual store physically already had a dent on the back and th tablet had a scratch but they claimed it was brand new. So why am I having a software issue with my iPhone 6s if it's brand new? There're all a bunch of crock...thinking of switching providers now
by
Add a comment
My problem is that my tab's company name is microdigital model M-7521 whenever I plug in the charger in it it's battery icon starts to flash and dissappear and my home screen doesn't opens what should I do?
Comments:
I'm having same problem any solutions
by
Same problem - have you figured this out? how can I get this to work?
by
Add a comment
My tab showing that the loading charging symbol while charging
Add a comment
The Battery connector might be loose, open the back cover and Solder it to make sure it is connected properly...
If the problem still persist then change the battery...
It should work...
Good Luck...
Add a comment
I had the same problems. Wouldn't charge, screen kept turning itself off. I pulled the back off and disconnected the battery and could see that 3 of the 6 copper teeth on the motherboard (that the battery connector plugs into) had come off the motherboard and stuck themselves to the connector. No way to remove them without destroying them so I stacked two pieces of cutup old credit on top of the battery connector and snapped the cover back on. It's pretty tight in there already, so the additional pressure was enough to keep the connector pressed hard into the motherboard and the power connection complete. No more problems. Won't last forever, but it'll do the trick until I can sort something else out.
Add a comment
Add your answer
Jojo will be eternally grateful.
Past 24 Hours: 285
Past 7 Days: 1,902
Past 30 Days: 7,935
All Time: 105,418
