The Kenmore Elite HE3 is a washing machine by Kenmore.
598 Questions View all
There's almost no water and machine keeps working.
When star , there's almost no water inside the machine; and 9 minutes before the cycle ends, just keeps working and never shutdown. Why?
Add a comment
1 Answer
Chosen Solution
First do a reset by unplugging the machine for 5 minutes.
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Score 1
Add a comment
Add your answer
papimami6968 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
