Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
877 Questions View all
iPod Classic 160 Gig Back light doesn't work
I accidentally washed my iPod classic but it works fine except the back light is out
Comments:
I made a mistake, I have only an 80 Gig and want to upgrade it while i have it open to a 160 Gig
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Thomas Overstreet, not quite sure how you washed it, but at minimum you will need need replace the HDD and the battery anyway since it will corrode and fail. While you have your iPod dismantled, clean everything with a high grade isopropyl alcohol and a soft brush. Do not forget any connectors etc. After that you will need to replace the display and hope that this will fix your backlight. If it does not, then the backlight circuitry on your logic board has shorted out.
Score 2
Add a comment
Add your answer
Thomas Overstreet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 89
