MacBook does not boot
My Macbook pro will not boot. On the underside of the computer is the serial #, no model number. I went to https://selfsolve.apple.com/wcResults.do
Based on apple, my macbook pro is ~VIN,MB Pro (15-inch, 2.53GHz, Mid 2009)
Serial Number: W89478GB7XJ
I need to change;
the battery
the hard drive 1 TB 7200 RPM 32MB CACHE SATA
more ram 8gb
screw driver set for unibody, battery, hard drive, ram
Thanks,
Lance
Before you go overboard here let's see if we can get the system to run with what you have now. I would hate feeling you spend money on a new drive, batt & memory that won't be useable if the system is not repairable.
by Dan
Can you tell us if the system boot up with just the power adapter plugged in and the battery removed. Does the battery have any charge in it when you press the batter check when you have it out?
by Dan
