Why did my screen resolution screwed up after a display change?
After my screen got changed in a repair store, the optimal retina resolution is the only one that works on the scales panel. I tried all the solutions, and I say ALL. I went to an Apple Store, we tried everything that was possible to fix this problem, even booting with a clean OS, but nothing worked.
So the problem is : the only resolution that works is the retina 1440x900, and the others are pixelised.
Do you have any idea ?
By the way, it's an LG display, and I think the old one was also and LG because I had the ghosting problem.
Update (10/30/2015)
If anyone has an idea related to that topic (I tried the whole process but didn't work) http://www.insanelymac.com/forum/topic/2...
1 Comment
I haven't found the EDID issue this person writes about as the issue with the internal display. I have seen this as an issue in some external DisplayPort displays. Most of the time cleaning the contacts or replacing the cable appear to resolve the problem. In some cases it was clear the issue was the display not the system.
by Dan
