Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why is my backlight not working?
I have just replaced the screen. Everything works OK now except the backlight.
I have completed a hard reset which did not resolve the problem.
I have also reseated and cleaned the screen contacts which did not resolve the problem.
Which contact strip is the one that controls the backlight?
1 Comment:
Did the backlight on your old display work before? why did you change the display? Try the old display again and see if the backlight works. Did you check the logic board to see if your backlight filters are okay?
by
Add a comment
It could be diode problem. you just blow it.
Add a comment
to rule out the backlight use the original screen to see if it still lights.
the backlight circuit is not in a strip and would require microsoldering repair.
Add a comment
Add your answer
Andrew Neaves will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 412
