Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Questions about replacing the logic board.
Right now I have a complete stock Mid 2009 13 in MacBook Pro, model A1278. It is about 5 years old. I want to replace some parts on it, most notably, my HD and my RAM.
I'm also planning on getting a new upper case (where the keyboard is) because I dented it on a corner not long after getting the computer.
Would it be possible though, to get a totally new logic board? I would like more processing power, so I was wondering if it would be possible to put in a logic board for a different model of the 13 in Macbook Pro?
Add a comment
1 Answer
Chosen Solution
On the most part you can only swept logic boards within the same series. In your case the MacBookPro5,5 which is only two models.
While some have managed to use other series there is always a risk the connections don't line up or the expected signaling is not compatible. Given the few Hz difference I don't think its worth the risks or the costs.
I think you can gain more performance just by upping the RAM as well as a faster storage. But before you go down that path what do you have now?
Update (09/19/2015)
OK, unless you are doing deep image editing or DB stuff or trying to run lots of apps at the same time 8GB should be plenty of RAM.
The drive its a bit tricky here. Given the systems age I wouldn't put to much money in as you will not likely get it out. I would look at a SSHD like Seagate's or a Dual drive like Western Digitals Black2 drive. Going with a straight SSD while nice, is expensive when you get the to larger sizes. Going with a dual drive setup (HD & SSD) by given up your optical drive only makes sense if the Western Digital Black 2 drive doesn't meet your needs space wise.
But, you still have one issue which could handicap you here the SATA ports speed for both the HD & Optical drive is only SATA II (3.0 Gb/s). So you do need to make sure what you get will run at that speed.
Last issues here is you do what to make sure you are running with the latest system firmware follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs as well as running the newest release of Yosemite if you go with either the WD Black2 or SSD drive.
Score 2
1 Comment:
I have 4 GB of RAM and a 250 GB HDD.
I am planning on upping my RAM and getting a new HD, but I'm also considering getting rid of my optic drive (but I'm leaning towards keeping it for now).
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
