2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
154 Questions View all
Is the topcase for the 2015 15" MacBook Pro different?
I have a 2015 15" MacBook Pro with a dented upper case (the keyboard assembly). I know about the glued battery situation and how the keyboards are attached. My question is, did the upper case change from the 2014 15" MacBook? I know the 2015 models have Force Touch, does that mean the upper case changed from 2014 to 2015?
Add a comment
Chosen Solution
The 2015 is the same model number A1398 as the 2013 & 2014.
Apple part number 661-8311 should work fine for you.
MacBook Pro 15" Retina (Late 2013/Mid 2014) Upper Case Assembly
MacBook Pro 15" Retina (Late 2013/Mid 2014) Upper Case Assembly Image
Score 1
Thanks again Mayer! I thought the only thing that would affect the differences might be the force touch module. I'll do a few more picture comparisons.
15" Retina mid-2015 topcase part number is 661-02536.
Add a comment
I just got my Macbook Pro 15 mid 2014 back from Apple Store repair. 661-8311 is written on the paper as the part number being changed but the thing is audio jack is a little bit misaligned towards one side. The first thing that came to my mind was that they put a different year's top case and it does not match the product but then reading this comment I came to realize that it is just the repair guy's mistake. Do you think the audio jack is being damaged in someway?
Add a comment
Add your answer
Evan will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 8
Past 30 Days: 21
All Time: 1,597
