Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Blinking folder, before and after changeing disk and install
Hi
Last night i started up my laptop, and it had a blinking folder in the middle (Worked 20 min earlier), and read that my computer didnt find my harddrive bla bla bla on the net, changed my drive, everything looked ok, installed the drive, rebooted, same error came up, whats wrong? i cant find the disk in disk utility (didnt fist time also), need help..
Add a comment
1 Answer
Chosen Solution
Do you have a friend with a Mac? If you do you'll need to visit them with a USB thumb drive and a good bottle of wine or some beer ;-}
What you'll need to do here is setup the thumb drive as a bootable drive and copy over it the OS installer your friend can download from the Apps Store if they haven't already downloaded it.
Using Disk Utility delete the current partition (likely FAT32) and create a GUID partition map and then create a Mac OS Extended (Journaled) partition. Once that is done you can run from your friends Mac the OS installer and select your thumb drive. Once done, reboot your friends Mac and hold the Option key so the boot manager comes up select the thumb drive to get it to boot up once up copy the OS installer you used over to it. Shut down the Mac so you can take the drive off.
Now to repeat the process on your Mac's hard drive. Of course finish the wine or beer first!
Score 2
2 Comments:
Tried that, still got the same error, looks like i need a new SATA cable, or find anything else ...
by
Bummer ;-{ Yep its the SATA cable then. If you can get a SATA to USB adapter you could also prep the drive externally to make sure its AOK.
by
Add a comment
Add your answer
trdahl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
