Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
96 Questions View all
My Ipod shows a directory/folder symbol & I can't seem to restore.
My original Ipod (middle on site picture of 3 ipods), constantly alternates between the apple symbol and a directory/folder symbol with an "!". I have connected to itunes, but the site either doesn't recognize my device or tells me that my device is corrupt & to restore. I go through the steps to restore, but after hours of restoring, I get an error message. I have never downloaded anything to the device excet through itunes. My disk drive is Toshiba mk 1003GAL HDD 1262 x zeo1. I am afraid that my device is now useless. Please help. Thanks.
Add a comment
Chosen Solution
Thanks mister790. I already unplugged & reattached the hard drive and the problem persisted with the series of "clicks". Did replacing the hard drive fix the problem or did you also replace the logic board and/or hard drive cable. Thanks!
Comments:
Replacing the hard drive did seem to fix the problem -- although the machine still freezes every once in a while. But it hasn't made those click sounds or died on me the way the previous iPod did.
by
And to clarify, since replacing the hard drive, I haven't had that empty folder or other warnings pop up on the screen or that failure to restore problem.
by
Add a comment
I had a similar problem with a 4th generation iPod. I opened the case and unplugged and replugged the hard drive, which seemed to make it work properly for a little while. But the problems kept recurring, and eventually the iPod would freeze and the hard drive would make a series of clicks. I finally decided the hard drive was dead and replaced it.
Add a comment
I'll go the new hard drive route. Thanks for your help!
Add a comment
Another thing to be sure of- make sure the harddrive cable isn't short circuiting anywhere. I had this happen to me once; I was taking a 3rd gen model apart, and I pulled the harddrive out. Upon reconnecting the harddrive, some of the ribbon tape ended up touching the harddrive pin contact points. It took me a while to figure out what was wrong. Eventually, I checked for the short circuiting, rebent the tape, and voila! My iPod stopped displaying the folder icon and booted just fine.
I would try that before you order any parts.
Add a comment
Add your answer
Jpod will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,172
