1.4GHz or 1.6GHz Processor, 64GB or 128GB SSD.
138 Questions View all
Can I swap a 1.6ghz 4gb board into my 1.4hgz 2gb MBA?
I have late 2010 11 MBA (macbookAir3,1). It has the 1.4hgz, 2gb ram logic board. Can I swap it out with the 1.6hgz, 4gb board without any problems and would it be worth the upgrade. I can get a board for around $150
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
As long as the logic board is from the same series (macbookAir3,1) you won't have any issues as the mounts and connections are the same. If you are trying to swap out with a different series all bets are off!
Follow this IFIXIT guide: MacBook Air 11" Late 2010 Logic Board Replacement. I would recommend cleaning and replacing the thermal paste on the CPU & GPU units on your new logic board.
Score 2
Comments:
Thank you sir!
by
Add a comment
Add your answer
DevAK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 75
