Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1391 Questions View all
How & what is needed for case replacement?
"What parts and tools do I need for a 'do-it-yourself' repair of the following items?"
1. Keyboard palm rest plastic has broken away at upper lid contact points.
2. Hinge plastic has cracked through on either side of connection to upper lid.
3. Lower case has cracked through at rear screws on either side of hinge.
4. Lower case has stress fractures underside along rear vent.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Most Helpful Answer
Here is the guide for the Bottom Case. Here is the guide for the Upper Case. This guide is for the Hinges. All the information on the tools needed for the repairs are noted on each repair guide. Good Luck!!
NOTE: iFix it carries parts for this machine. Select your exact model here, and browse through the parts section.
MacBook Core 2 Duo Upper Case Image
Guide
MacBook Core 2 Duo Upper Case Replacement
Difficulty: Moderate45 minutos - 2 horas
Score 1
Comments:
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 957
