Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
515 Questions View all
Replacement LCD Panel includes adhesive?
Hello! Everyone!
MY mid 2010 macbook pro's matte lcd panel is starting to go bad and i'm considering buying the replacement lcd.
But i'm just wondering if anyone know if it comes with the double sided adhesive with the replacement panel?
Thank you very much!
J
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Your best bet is to either buy the full assembly or to get a new panel as its not very hard to replace and the adhesive you need is able to be found on ebay for $3-5 for a nice role of it.
Add a comment
Thank you so much! I think I will grab the Lcd Panel here and get the adhesive from eBay or something then!
Comments:
No problem this is the adhesive i like to use http://www.ebay.com/itm/10mm-25m-Red-Dou... But if you are really carful and use enough heat but not enough to melt the rubber and you can sometimes get the bezel off without damaging the adhesive the adhesive and just stick it back off but its really just skill and luck to do that haha. Best of luck with the repair. Make sure you scrape all the old adhesive very well of the adhesive doesn't stick well but if it has a good surface to grip too then it hold great
by
Thank you so much! Miles Blakesley! Will Definitely do it slow and steady and hope everything goes well! *fingers cross*
by
Add a comment
Add your answer
SectionJ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
