Fix Your Stuff
Right to Repair
Parts & Tools
Repair and disassembly guides for Epson printer.The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
483 Questions View all
Epson WF-3520 firmware update failure
When putting the drivers into a new Win7 install, Epson's search-and-destroy printer identifier and installer decided on its own to update firmware; of course, it crashed. Printer is now stuck in partial-start state - when you power it up, Power LED flashes and beeps once or twice as normal, display starts to come up, then it quits.
I have the firmware updater utility that is SUPPOSED to work, and a couple of the Epson service programs, but they will not connect to the printer via USB.
What is the procedure to do a hardware reset on the WF-3520 (panel keys held down, timing...) to get the bootloader in the microcontroller to reset and go to the "Recovery Mode" function where you can install firmware?
Score 1
Add a comment
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Most Helpful Answer
Try to update the firmware for your printer by following steps: (This process is only applied in window version only)
  1. Make sure your Epson product and computer are connected to the same wireless network
  2. Click Start Button or Start > All Programs or Programs > Epson Software > Epson Software Updater. If you don't see Epson Software Updater in the Epson Software folder, go to the Epson Software Updater page to download and install the utility.
  3. When you see the screen, select the check box next to each available update and click Install.
  4. Follow the on-screen instructions to update your product's firmware.
Its all done now.
For more info please refer to Epson WorkForce WF-3520 Manual.
Score 1
Comments:
Despite this is for a d different printer than my 7620 and it was a Windows 7 generation issue, it does not respond to the core problem which is the Epson Software Updater fails continually. Getting sent to a website that tells you to go through the process that does not work is of not value at all.
In addition Epson has refused to respond to direct requests for help with this. I would like to be able to download the needed files and update my fimware without using the Epson Software Updater. Oh yea, I reinstalled the upload too so I know it is fresh and running.
by
Add a comment
I solved this problem by trashing the printer. Because ”epson assistence” was to change the mainboard with a cost that surpasses the printer value itself. I’ll never buy an Epson for the rest of my life. Amen.
Add a comment
HI,
You have to replace the eprom chip with the new one and your printer will work again like new.
You can find the eprom chip in online store.
Comments:
"You need more reputation points to vote someone down." Ha, more BS. It still does not help me. A search on the Epson website for eprom chip returns a variety of gadgets to hang a TV from the ceiling.
by
Add a comment
Add your answer
Andy S will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 57
All Time: 9,623
