Repair and disassembly guides and support for dish washing appliances.
704 Questions View all
Whirlpool ADP A CLASS ADP 4305 Dishwasher not wanting to start.
My dishwasher is not starting, it is giving 1 flash every time it is trying to start. I can hear a motor trying to start.
The tap is open. I checked all the hosing pipes - no leaks found.
I managed to powered on the dishwasher with the door open to investigate more - I can see that the water is filling up slowly in the hole where the filter goes and little bit of water is coming out by the outlet when it tries to start.
Thank you in advance.
Score 1
3 Comments
Hi
Thank you for the reply.
I have uploaded a video on what the machine is doing.
[video|263]
by
But you need to post it to this question so I can see it.
by
Hi Mayer
I insert it but then all I see is [video|263].
Is there something that I am not doing?
by
Add a comment
1 Answer
Chosen Solution
Heating Element
The heating element heats up the water to operating temperature. If the water doesn’t reach the proper temperature after a set amount of time, a light on the control panel might start flashing. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Score 1
Add a comment
Add your answer
Ggo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 910
