Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s will not turn on? Changed everything outside componen level.
I have an iphone that has not been near water but has been dropped how hard i do not know. the screen was cracked so i replaced it for a good working one one week later the phone turns off and wont turn on i replaced the battery charging port power button and even the camera but no luck i tested the old and new parts they all worked the battery gives off good volts and so does the charging port. when i try to turn on the phone with an power supply at 3.7 nothing happens and like i said the screen works i tested it before and after and it has image. do i have to replace the IC chip........
Score 1
Add a comment
Can anyone follow up on tonny's problem?? cuz i am having the same issues . Thank you
Add a comment
Check FL47 most likely is been knock off or moved a little i had this issue before nothing will happen until i solder it back it place and everything work perfectly.
Add a comment
Add your answer
Tonny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
