Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3941 Questions View all
Blank screen after screen replacement.
Hi, really hope someone can help me. I have read a lot of other questions relating to this on here but none quite the same (I don't think).
My screen smashed on my iPhone 6 so I have replaced it. I swapped all the parts to the new screen, plugged in all the connectors and turned it on to test it.
I must say at this point, I did not replace the shield yet so this can not be long screw damage.
The screen worked but the finger print scanner did not. So I popped the connectors off (I admit I forgot to power down first) disconnected to finger print scanner and reconnected. I plugged the screen back in and nothing, just blank.
The phone works, if I flip the silent switch it vibrates. I can hard reset to turn it off, turn it back on but the same. I have plugged the screen into another 6 and it works perfectly.
Any idea what to do/try?
I can't reset in iTunes as the passcode is on and the screen is blank!
Any help is appreciated.
Thanks in advance
Score 1
Add a comment
Most Helpful Answer
Try this.
Disconnect the battery, Then plug the screen in, reconnect the battery. Now turn the phone on. Likely this will fix it. if it doesnt then yes you likely blew the backlight fuse.
Score 2
Add a comment
It sounds like it might be an issue with the backlight. Possibly because you didn't turn off the phone when removing connectors.
To fix it would be a case of locating the faulty component and replacing it. Unfortunately most of the backlight components are under the metal shield and will require quiet good soldering skills.
Score 1
Comments:
Was so hoping that this wasn't the case.
by
Im having this same issue but I don't understand the whole blacklight thing.. How can i fix my phone without it being super costly
by
Add a comment
Add your answer
Ali will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 616
