Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1391 Questions View all
Is it worth upgrading RAM?
Hi everyone !
I have a MacBook Core2Duo 2,13 Ghz (late 09).
I put an SSD into it, but the laptop tends to overheat. I also experience some freezes.
According to everymac.com, RAM can be upgraded up to 6gb (so 4gb + 2gb - I know it seems weird but apparently it works).
The thing is, 4gb DDR2 sticks are unsanely expensive, about 140$.
So I'm considering a 2*2gb upgrade.
My question is :
- do you think it will help the CPU to cool down (and the fan to slow down by the way !) ?
- will it make the computer be smoother ?
Thanks a lot guys !
Max
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
First you need RAM Type: PC2-6400 DDR2 Min. RAM Speed: 800 MHz
and you only need one 4GB stick. The other can be a 1 or 2GB.
A single 4GB should run about $70.
Next the RAM is not your heat problem. Open the machine, remove the fan, blow it out and clean the vent.
If the heat problem persists, you may need a new application of thermal paste.
MacBook Core 2 Duo Heat Sink Replacement
Score 2
Comments:
Thanks for your answer !
I don't find stick this cheap... seems to be the regular price for standard stick, not for 200pins ones.
Anyway, I think I'll consider upgrade with 2*2gb and then have a look on the thermal paste.
by
Add a comment
Add your answer
Maxime Muller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 138
