The Polaroid One-Step 600 Camera takes and develops its own pictures. It features an automatic flash as well as a special lens for close up photos.
32 Questions View all
Displaced spring in film release button?
A spring fell out from the left side of the film cartidge loading bay and I can figure out where it goes. It is a large u-shaped with a hook at each end. I am surmising it works to activate the release button to load film. If I had a schematic or exploded view of the camera, it might help to relocate it. Any suggestions?
Score 1
Add a comment
Most Helpful Answer
i think the best way is to use the pictures of the teardwon for that camera: CLICK
it's surely not a repair guide (but if you look on the right side, there are 3 step-by-step guides) - but it's shows the most of the inside parts of the camera
Score 1
Add a comment
Thanks, Marcus! I appreciate the help.
Add a comment
Hi
Did you ever resolve this issue. The same thing has happened to mine. I'm pretty sure it's the door latch spring.
Thanks
Stuart
Add a comment
Actually the U-shaped spring is the one that lets the door latch engage with the body. It is located at the right side of the Roller Assy looking from behind the camera. Observe the way it mounts on a functional camere, it´s tricky to describe in writing. The metal part it activates is visible on Step 9 of the dismantlich pictures.
Add a comment
Add your answer
kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,461
