Thanks for the help
Just wanted to say thank you, Not having worked with small flex circuits before I found the pictures very good. The only thing that challenged me was understanding how the little latches on the flex connectors worked so i didn't break them. Also when I received the battery as I replaced the hard drive and battery the flex circuit from the new battery was backward and I wasn't sure if the power was backward as well. No help from the supplier other that wire it up and see if it worked, i wasn't willing to do that.
Instead in checking the outputs tedious at best, found they were the same. I mean if you received this would you risk letting the smoke out?
"The flex cable can't influence the item , you could put it into your ipod and check the item ,if the item can't work ,pls kindly let me know ,tks !"
Anyhow thanks for having this available.
Bruce McGraw
