AC adapter for MacBook, MacBook Pro, and MacBook Air
69 Questions View all
AC adapter 60W MaGsave donct charge. NO 6.8V cable OK?
MacBook 2008 MagSave stopped charging.
CAble OK but Adapter wont give required 6,8V, nothing.
Warms a bit but not mutchs.
Needs repair. Is it possible DIY* any common faults
Add a comment
Chosen Solution
Hi Mayer
Thanks alot Of your trouble to answer to my Littellin problem.
Yes I tried to Have a closer look Of The pins and their free movement, ok, cleaned them and also on Mac end. No life on pins. With another charger all works.
Finally I Cut The chord and mesured voltage on The two wires ( shield and inner wire) no voltage.
Seems The Fault Is In The adapter?
Is it worth for DIY Man try to fix?
Opened The cover and had a visible look but no burnings or el. Smell..
Pretty impressive content!
Add a comment
Most Helpful Answer
I take it you have tested the output pins with a multimeter. Here are the repair guides: Apple AC Adapter Repair
Make sure the pins (which are retractable) are extending fully. I use a wooden tooth pick to test.
Most of the time the case gets destroyed when opening the things. It just about takes a Mac truck running them over to open and there are few replaceable parts unless the issue is with the cable.
The pin out voltages are only on pins 2 & 4 and are listed on the right side of this page: https://en.wikipedia.org/wiki/MagSafe
Score 1
Add a comment
Add your answer
info will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 146
