power button wont work, stays on
not sure if it is a 2nd or 3rd gen. 16gb. model mb531ll.
everything works but the power button. it will charge and play everything but stays on until the battery dies.
any suggestions?
any suggestions?
it's a second generation ipod touch
if the power button fails, it's in most cases a fluid damage or a worn out switch.
you can use the Power-Volume-Controls-Replacement guide to get to the ribbon cable.
check the actual switch if it look's corroded (white/greenish) or i any way damaged. those switches are simply thin metal plates, secured by a plastic strip/scotch tape..
if you find some corrosion (check the connector of the cable too) - clean it with isopropyl alcohol (>90%) - if the metal inside the switch is black, use a needle to "scratch" it carefully of the metal - don't bent the thin metal to much
thanks for the info. I looked under "parts" and it doesnt show a power/volume control. Any idea where I'd get one?
i buy those things on ebay - here is a search for that part on ebay.com: CLICK
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 17,408
