Popular laptop sold by HP. Comes in a wide variety of configurations but retains the same basic form factor in all. The numbers and letters that follow "G60" usually indicate what retailer sold it and what hardware came in it.
51 Questions View all
Why it is not charging although charger seems working?
the pilot lamp to indicate charging when the chrger is plugged in does not glow. the chrger tested to give around 19v. the battery temp is normal and no indication that the presense of the charger is sensed. the charger remains cool and the battery continues to discharge. before that, the charger plug input at the side of the laptop was very hot.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
sound like the charger socket on the mainboard is broken or has faulty solderings - but it would be a very common problem.
can you move the plug slightly when its connected to the socket?
Score 1
Comments:
thank you markus. i moved the plug a little but no hint of connectivity. i'd suspect faulty soldering, as you suggested, or disconnected internal wiring due to excessive heat(?). i tried to look inside the casing, but with so many screws around, i gave up. thanks again
by
don't let the screws scare you - it's not that bad. you can use a copy/print of the bottomside of your computer to sort the screws, or use the service manual (click) - it has a screw guide in it.
by
thanks. I think i'll try the disassembly some time very soon.
by
Add a comment
Add your answer
nasr ennasr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 3,605
