How do I replace the starter. on a 2005 chev equine equnix
Looking on . How to replace the starter o. A 2005 Chevy equals.
waltercharlesktn see if this will help:"
Removal Procedure
1. Disconnect the battery negative cable from the battery. Refer to Battery Negative Cable Disconnect/Connect Procedure.
2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
3. Remove the starter motor solenoid positive terminal nut and electrical wires.
4. Remove the starter motor solenoid S terminal nut and electrical wire.
5. Remove the torque converter cover bolt (2).
6. Remove the torque converter cover (1).
7. Remove the starter motor bolts (2, 3).
8. Remove the starter motor (1).
How to remove starter on a Chevy 2005 equinox
What is wrong with the above instructions?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 11,115
