Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Questions View all
Is it a Video card Issue? (No Display or Black Screen)
I have replaced the power supply of an iMAC 20" Intel a1224(EMC 2210) when i finish and turn on the machine it has no display... I have noticed that the fourth diagnostic LED is not light...
601, 602, and 603 is ON, but 604 is OFF.. would it be the video card issue? just want to make sure before i replace the video card.
Update
two weeks ago, when i received the video card i order online i immediately teardown my MAC and replace the old video card, and luckily the system is now running in very good condition.
Score -1
3 Comments
good day evryone!
mayer, ive replaced the power supply cause when the system turned ON, theres no response on system and LED1 is not ON also.
two weeks ago, when i received the video card i order i immediately replace the old video card, and luckily the system is now running in very good condition.
by
I am having the same issuse and was wondering if you have found the solution to the problem at hand any help would be awesome
thanks
by
Chris, please start your own question. I don't think you would like it if a doctor gave you medication based on an examination of the guy before you just because you both had a fever.
by
Add a comment
Chosen Solution
Hook it up to an external monitor to help isolate the problem. Why did you replace the power supply and what symptoms led you to do it?
LED 1 indicates that trickle voltage from the power supply has been detected. This LED will be ON when the computer is turned off and your power supply is working correctly.
LED 2 indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 indicates that the computer and the LCD display are communicating. This LED will be ON when the computer is turned on and video signal is being generated.
LED 4 lights only if the computer detects an over-temperature condition. This LED will be OFF when the computer is turned on and running at the correct temperature.
Score 4
2 Comments:
Good info +
by
mayer, where is those LED's located?
Thanks.
by
Add a comment
I spoke with a rep from apple and was told the black screen issue is caused by either a faulty backlight bulb or faulty video card. At the time of this writing, my imac is being repaired and was informed the video card needs replacing. Dave C
Add a comment
Add your answer
Cled Tayamen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 7,183
