The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
582 Questions View all
Is motherboard from Galaxy S III neo compatible?
My Galaxy S3 dropped on the ground after that the sounds comin from phone were so ugly : ( i tried to change only the speaker but no success. So i have to change the motherboard and i`m askin is it possible to take motherboard from Galaxy S 3 Neo which is absoliutely the same phone with some better specs or i have to put motherboard from S3?
Thank you for your response... : )
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
for things like this specs do not matter what matters is the layout of the board. short answer is probably going to be a no. long answer you would need to look at the boards physical size from every direction including the height of the components, the look at how the components are arranged. you will then have to make sure that your carrier will support the new guts of the device as well.
Score 1
Comments:
Ok man thanks for the response.. so i better do not do any experiments : )
by
Add a comment
Add your answer
Milen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 186
