Model A1138 / 1440x960 screen resolution
99 Questions View all
Why is my PB overheating?
I have an old PB 1.67 GHz, and the funny thing started to happen, i use hardware monitor to check temperatures inside my laptop and it is showing temperatures from 49 up to 75 degree celsius. What can i do to lower temperatures cuz 57 degrees as "normal working temperature" i think it isnt usual. Any advice would be handy...
Comments:
Are you experiencing any actual problems as a result of this? Fluctuation in temperature is normal.
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
i did all that but i discovered also a big gap between left fan and heat sink,there is like 3mm wide gap. Will need a new heatsink i guess...
Add a comment
Most Helpful Answer
hi just wanted to give some note with regards to your problem...you only need to clean the fan and the parts around it where it is connected. Else if your fan rotates very slowly than the normal one-its better for you to find a replacement fan.
Score 1
Add a comment
Add your answer
Filip will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,196
