Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
blank screen, click wheel still clicks, swapped HDD, Logic board Shot?
follow up to my last question:
iPod 5g blank screen, hdd clicking......
I've already swapped out the HDD with both a new Toshiba and also tried a CF conversion. Went through iTunes and tried restored it, now I get a black screen and nothing more. I can hear the click wheel clicking with each press, but nothing on the screen. Quadruple checked all connections, nothing working.
At this point, could the Logic board be shot? Would changing out the Logic board make it miraculously again?
Score -1
1 Comment
Please post this as an Update to your original Question
by
Add a comment
Most Helpful Answer
The so called "genius" was right, the hdd dies - but you can try something with your iPod - if it works - keep in mind that the hard drive could die within minutes, days or years - nobody knows...
hold the iPod around 4" above and "drop it" - make a hard reset and if you are lucky - it will work again
here is a howto video on youtube
the white screen has nothing to do with the clicking, i would try a hard reset (press and hold the menu and the select button at the same time until the iPod restarts - that should be done within 10 seconds)
Score 1
Add a comment
This answer was originally to another question.
I tried the drop, didn't work. Might just try replacing the HDD later, start from there.
Add a comment
Add your answer
ryo808 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,763
