Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
58 Questions View all
What is the lining on the iPad called?
Is there a name to the black plastic lining in between the iPad glass and the metal case? I replaced a iPad 2 CDMA glass screen, and I wasn't able to get it in flush without removing the plastic lining. I tried to put the lining back, but it is broken is 2 to 3 places and tiny bits are missing so it looks bad. Any way to buy the item or something to use in replacement to cover the gap?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
TheChosenMammal, from your description I can only think of the Bezel Gasket. Take a look on here and see if that is what you are referring to.
Score 3
Comments:
Thank you so much, I didn't know the name. That's exactly what I was referring to!(:
by
Add a comment
Add your answer
TheChosenMammal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 66
