Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19998 Questions View all
Why is my computer shutting down for no reason?
My aluminum MacBook is about 2 years old now. I use it very often, so perhaps this is just normal? It turns off randomly, without warning, with more than enough battery power left. It's happened 4 times in the past month or so and I'm beginning to get worried! It just happened today, after I unplugged my adapter for about 15 minutes. I left the computer off for 4 hours. When I returned to it, I plugged in the adapter and turned on the computer...turns out there was still 55% of the battery left! I really hope someone can help me figure out what the problem is...
Here is what my System Profiler says about my Power:
Battery Information:
Model Information:
Serial Number: DP-bq20z951-3a2c-4a24
Manufacturer: DP
Device name: bq20z951
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 002a
Hardware Revision: 0005
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 2338
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 3245
Health Information:
Cycle count: 551
Condition: Good
Battery Installed: Yes
Amperage (mA): 385
Voltage (mV): 12293
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 15
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 15
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 0
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: Yes
Thanks for reading!
Score 1
1 Comment
+ Great details on the question!
by
Add a comment
1 Answer
Most Helpful Answer
This sounds like it could be an overheating issue. Has it been rebooting after you've been doing particularly graphics / cpu intensive processes? Watching online videos or playing games would be two fo the big ones. Older computers tend to accumulate dirt, dust, etc inside them after that long of a time. My first recommendation would be to clean out the inside of your computer.
To find out what kind of MacBook Pro you have, you can use our ID-Your-Mac tool. After you know which model you have, you can use one of our appropriate guides found from this MacBook Pro device page.
When you open it up, try using some canned / compressed air to blow out and remove the dust you're likely to find. Hopefully this will improve your situation. :)
Score 1
Add a comment
Add your answer
Dian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,446
