The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3363 Questions View all
Where does this piece go?
hello, I had to replace the power button, i replaced it and everything went fine except that the wifi signal now is very weak. I have this little piece and i don't remember where it goes.
Looking at the videos on youtube I don't find it.
Maybe it's the cause of the wifi weak signal.
I checked everything again but still don't know where to put this small piece:
http://imgur.com/qm9BB7K
Comments:
Could that be the reason why the wifi signal is weak?
by
Possibly only if it provides contact between your antennae and the board.
by
Where does that piece go? generally the floor of shoddy repair shops being run out of the back of a nail salon... Where did it COME FROM? Where should you put it? See Old Turkey's response...
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
dannyzanchi, it is located beneath the bracket to the left of the rear-facing camera. Check this guide step 31
Score 2
Comments:
even after putting the piece my wifi signal is very weak :(
by
the wifi antenna is that connector that you have to plug into the back side of the board before re-installing it in the frame. You didn't forget did you? Sometimes they just don't quite make connection like they should, maybe unplug and re-seat that antenna.
That antenna can be seen in OldTurkey's picture in the bottom third of the picture almost in the center just above (or in this orientation, to the left of) the battery.
by
thank you,
this is the antenna, on the side that you can see on the top of this pic it doesn't make any connection with the board. And I didn't lift the antenna. I can't understand why it's not making a good connection with the board.
http://g02.a.alicdn.com/kf/HTB1F5QtIXXXX...
by
Add a comment
Add your answer
dannyzanchi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 146
