The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
36 Questions View all
I have code P0306 any help or suggestions?
Code says cylinder #6 misfire I've already replaced spark plugs and coil pack so i dont know what other thing it could be please help
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
carlosleonardos,The P0306 code means that the cylinder 6 is misfiring or is randomly misfiring. Start by checking for intake leaks. Since you already replaced the plugs and the coil pack there are a more possibilities
# Clogged or faulty fuel injector 6
# Fuel injector 6 harness is open or shorted
# Fuel injector 6 circuit poor electrical connection
# Insufficient cylinder 6 compression
# Incorrect fuel pressure
# Intake air leak
Score 2
Comments:
Could i Just buy injector cleaner at an auto parts place and see if that fixes it ??
by
You could by I have never been impressed with that stuff. Nothing to lose I suppose, so you might as well give it a try.
by
i waited a couple days to see because i bought an injector cleaner but my jeep is still doin the same thing shakes when im at a light or idle
by
Then continue down the line with the trouble shooting. i.e. replace injector
by
Add a comment
Add your answer
carlosleonardos will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 39
Past 30 Days: 145
All Time: 2,987
